查看: 2964|回复: 0
【SD】SM268BF [复制链接]
发表于 2011-12-21 10:39:52 |只看该作者 |倒序浏览
Controller marking :  SM268BF
Memory chip marking :  K9LAG08U0A
Memory chip ID :  0xECD555A5
Variant 1 Author: EDILTON [18]
Translator Type 19 [SM267BB]
GMT+8, 2026-8-26 19:27 , Processed in 0.101775 second(s), 13 queries .
