查看: 4145|回复: 0
【SD】Glued PCB SD43S-V1.2 SumaTech [复制链接]
发表于 2011-12-21 13:55:17 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SD43S-V1.2 SumaTech
Memory chip marking :  K9GAG08U0D
Memory chip ID :  0xECD59429
Variant 1 Author: Karol [217]
Marker Pos513
ID3412
GMT+8, 2026-7-12 20:36 , Processed in 0.102870 second(s), 14 queries .
