查看: 4877|回复: 0
【SD】Glued PCB SM2682L NSD101-SMI-2682LT-2L-LGA [复制链接]
发表于 2011-12-21 13:16:12 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM2682L NSD101-SMI-2682LT-2L-LGA
Memory chip marking :  D27UCG8UDMYR
Memory chip ID :  0xADD79425
Variant 1 Author: KuttingEdge [137]
Translator Type 14 [SM267LT]
Page size 4320
Sector size 571
0-512;512-27;
539-512;1051-23;
1074-512;1586-23;
1609-512;2121-23;
2144-512;2656-23;
2679-512;3191-23;
3214-512;3726-23;
3749-512;4261-59;
GMT+8, 2026-8-26 19:27 , Processed in 0.137500 second(s), 14 queries .
