查看: 4797|回复: 0
【SD】Glued PCB NSD101-2.0-SMI2683-EN-2F-2L [复制链接]
发表于 2011-12-21 14:34:21 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NSD101-2.0-SMI2683-EN-2F-2L
Memory chip marking :  HY27UBG8T2ATR
Memory chip ID :  0xADD7949A
Variant 1 Author: Karol [217]
Marker Pos513
Block Size8192
Mask0x03FF
Full BlockYES
Page size 8640
Sector size 538
0-512;8528-26;
512-512;8528-26;
1066-512;8528-26;
1578-512;8528-26;
2132-512;8528-26;
2644-512;8528-26;
3198-512;8528-26;
3710-512;8528-26;
4264-512;8528-26;
4776-512;8528-26;
5330-512;8528-26;
5842-512;8528-26;
6396-512;8528-26;
6908-512;8528-26;
7462-512;8528-26;
7974-512;8528-26;
GMT+8, 2026-8-26 19:15 , Processed in 0.103082 second(s), 13 queries .
