查看: 10569|回复: 1
希捷硬盘保修查询官网网址 [复制链接]
    发表于 2011-8-23 17:47:57 |只看该作者 |倒序浏览
    希捷硬盘是否在保修范围内官方查询界面,输入 SN 和 PN,中间有一个空格,如图所示
    http://support.seagate.com/customer/warranty_validation_multi_cn.jsp
    查询结果如下
    In Warranty
    • This drive is covered by a Seagate warranty.
    • If the drive is defective, it may be returned for exchange. You will not receive your original drive in return. Please do not return a healthy drive. Seagate reserves the right to return a good drive back to its owner and to charge for all associated shipping costs.
      Test with SeaTools to verify the drive is failing and save the SeaTools Test Code result number to validate the drive failed SeaTools testing.
    • Please back up all data before returning the drive.
    • Please return all accessories that were included with your product.
    • To return defective accessories within the listed warranty period, please contact Customer Service for details
    翻译如下
    在保证
    这个驱动覆盖希捷保修。
    如果驱动,是有缺陷的,它可以返回用于交换。你不会得到你原来的驱动的回报。请不要交回一个健康的驱动器。希捷公司有权返回一个好驱动归还原主和收取所有相关的运输成本。
    试验验证了驱动SeaTools失败和拯救SeaTools测试代码验证结果数字驱动失败SeaTools测试。
    请回来之前把所有数据驱动。
    请把所有的配件,包括你的产品。
    还在有缺陷的配件上市保质期内,请联系客服的细节。
    发表于 2011-10-1 10:02:15 |只看该作者
    正在找这个东西 谢谢了
    GMT+8, 2026-9-10 03:24 , Processed in 0.110216 second(s), 17 queries .
