查看: 3165|回复: 0
【CF】SM222TF [复制链接]
发表于 2011-11-9 13:47:51 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM222TF
Memory chip ID :  0xADD314A5
Variant 1 Author: ondata [10]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 17:24 , Processed in 0.099640 second(s), 13 queries .
