查看: 2614|回复: 0
【CF】SM223TF AC H32795 0849 [复制链接]
发表于 2011-11-9 12:29:38 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM223TF AC H32795 0849
Number of memory chips :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  16384
Variant 1 Author: datadisk [4]
Initial memory chips (4)
Block Number Type 2 [SM32xx]
Block Size8192
Use Add-insNo
Full blocksNo
Variant 2 Author: majedawad [3]
Block Size8192
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 19:13 , Processed in 0.103481 second(s), 13 queries .
