查看: 3486|回复: 0
【SD】Glued PCB SD-002-S3 SA SM2683ABU [复制链接]
发表于 2011-11-9 13:08:20 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SD-002-S3 SA SM2683ABU
Memory chip marking :  29F64G08AAMEI
Memory chip ID :  0x8988244B
Capacity(Mb) :  16384
Variant 1 Author: Stannik [13]
Join by block fo N sources (Block Size 16)
Marker Pos513
Block Size16384
Page size 8576
Sector size 538
0-512;8528-26;
512-512;8528-26;
1066-512;8528-26;
1578-512;8528-26;
2132-512;8528-26;
2644-512;8528-26;
3198-512;8528-26;
3710-512;8528-26;
4264-512;8528-26;
4776-512;8528-26;
5330-512;8528-26;
5842-512;8528-26;
6396-512;8528-26;
6908-512;8528-26;
7462-512;8528-26;
7974-512;8528-26;
GMT+8, 2026-7-12 17:24 , Processed in 0.099992 second(s), 13 queries .
