查看: 2679|回复: 0
【NoName】TCC767 H301-AP-R3 UBG-P 0640 [复制链接]
发表于 2011-11-9 11:11:05 |只看该作者 |倒序浏览
Flash device type :  NoName
Controller marking :  TCC767 H301-AP-R3 UBG-P 0640
Memory chip marking :  K9WAG08U1M
Memory chip ID :  0xECD35195
【ILLUSTRATIONS】
0        1
Parts of memory chips (2)
0        1        2        3        4        5        6        7        8        9        10        11        12        13        14        15
Split by dump (Dump number 16)
0        1        2        3        4        5        6        7        8        9        10        11        12        13        14        15        16        17        18        19        20        21        22        23        24        25        26        27        28        29        30        31
Split by block (Block Size 256)
0        2        1        3        4        6        5        7        8        10        9        11        12        14        13        15        16        18        17        19        20        22        21        23        24        26        25        27        28        30        29        31
Change order (New order 0,2,1,3,4,6,5,7,8,10,9,11,12,14,13,15,16,18,17,19,20,22,21,23,24,26,25,27,28,30,29,31)
Marker Pos        514
Block Size        256
Even Block        No
【Page size transformation】
【Solution file】
GMT+8, 2026-7-12 21:37 , Processed in 0.090271 second(s), 13 queries .
