查看: 3001|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-11-9 13:08:16 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Number of parts :  4
Memory chip ID :  0xADD314A5
Variant 1 Author: Karol [204]
Parts of memory chips (8)
0123456789101112131415
0213
Change order (New order 0,2,1,3)
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
GMT+8, 2026-8-26 23:40 , Processed in 0.102185 second(s), 13 queries .
