查看: 2413|回复: 0
【SD】Glued PCB AU7651/41 [复制链接]
发表于 2011-11-9 09:52:50 |只看该作者 |倒序浏览
Controller marking :  Glued PCB AU7651/41
Memory chip marking :  TC58NVG2D4BFT00
Memory chip ID :  0x98DC84A5
Capacity(Mb) :  512
Split by block (Block Size 4)
Change order (New order 1,0)
Marker Pos513
Block Size256
GMT+8, 2026-7-13 00:32 , Processed in 0.104912 second(s), 13 queries .
