查看: 2449|回复: 0
【SD】Glued SA SM2683ABU [复制链接]
发表于 2011-11-9 10:31:52 |只看该作者 |倒序浏览
Controller marking :  Glued SA SM2683ABU
Number of parts :  4
Memory chip marking :  SDZNMMDHER-032G
Memory chip ID :  0x45DE9532
Capacity(Mb) :  32768
Variant 1 Author: l32 [63]
1023
Change order (New order 1,0,2,3)
Marker Pos513
Page size 8576
Sector size 558
0-512;8528-4;1024-42;
512-512;8528-4;1024-42;
1066-512;8528-4;2090-42;
1578-512;8528-4;2090-42;
2132-512;8528-4;3156-42;
2644-512;8528-4;3156-42;
3198-512;8528-4;4222-42;
3710-512;8528-4;4222-42;
4264-512;8528-4;5288-42;
4776-512;8528-4;5288-42;
5330-512;8528-4;6354-42;
5842-512;8528-4;6354-42;
6396-512;8528-4;7420-42;
6908-512;8528-4;7420-42;
7462-512;8528-4;8486-42;
7974-512;8528-4;8486-42;
GMT+8, 2026-7-13 00:00 , Processed in 0.093114 second(s), 13 queries .
