查看: 2524|回复: 0
【SD】Glued PCB SM268BB_SD [复制链接]
发表于 2011-11-9 11:10:57 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM268BB_SD
Memory chip marking :  K9GAG08U0D
Memory chip ID :  0xECD59429
Marker Pos513
ID3412
GMT+8, 2026-7-12 21:26 , Processed in 0.103127 second(s), 13 queries .
