查看: 2387|回复: 0
【SD】SD CARD NONAME (Phison PS8000S) [复制链接]
发表于 2011-11-9 09:52:45 |只看该作者 |倒序浏览
Controller marking :  SD CARD NONAME (Phison PS8000S)
Memory chip marking :  TH58NVG3D4BTG00
Memory chip ID :  0x98D384A5
Capacity(Mb) :  1024
Variant 1 Author: Mekanik [14]
Block Rotate (Block Size 0,Marker Pos 0,Id 1234,Mask 0x0000,Small Block 0)
Block Size512
Mask0x0FFF
Full BlockYES
GMT+8, 2026-7-13 00:33 , Processed in 0.106995 second(s), 13 queries .
