查看: 2338|回复: 0
【SD】glued [复制链接]
发表于 2011-11-9 10:31:49 |只看该作者 |倒序浏览
Controller marking :  glued
Number of parts :  4
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  16384
Variant 1 Author: LCTECHNOLOGY [5]
Mask0x03FF
Page size 4320
Sector size 539
0-512;512-27;
539-512;1051-23;
1074-512;1586-23;
1609-512;2121-23;
2144-512;2656-23;
2679-512;3191-23;
3214-512;3726-23;
3749-512;4261-27;
GMT+8, 2026-7-12 23:15 , Processed in 0.100013 second(s), 13 queries .
