查看: 2423|回复: 0
【SD】Glued PCB NoName SA SM267LT [复制链接]
发表于 2011-11-9 11:10:54 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NoName SA SM267LT
Memory chip marking :  MT29F16G08MAA
Memory chip ID :  0x2CD5943E
Variant 1 Author: rhensel [4]
Translator Type 14 [SM267LT]
Page size 4304
Sector size 608
0-512;512-16;
528-512;1040-16;
1056-512;1568-16;
1584-512;2096-16;
2112-512;2624-16;
2640-512;3152-16;
3168-512;3680-16;
3696-512;4208-96;
GMT+8, 2026-7-12 22:18 , Processed in 0.096513 second(s), 13 queries .
