查看: 2609|回复: 0
【SD】SK6626ACSC A0902 CML23122.9 [复制链接]
发表于 2011-11-9 11:49:58 |只看该作者 |倒序浏览
Controller marking :  SK6626ACSC A0902 CML23122.9
Memory chip ID :  0x89D5943E
Change order (New order 1,0)
Mask0x03FF
ID3412
Full BlockYES
Page size 4304
Sector size 538
0-512;4096-26;
512-512;4122-26;
1024-512;4148-26;
1536-512;4174-26;
2048-512;4200-26;
2560-512;4226-26;
3072-512;4252-26;
3584-512;4278-26;
GMT+8, 2026-7-12 19:55 , Processed in 0.091627 second(s), 13 queries .
