查看: 2405|回复: 0
【SD】PS800x (glued) [复制链接]
发表于 2011-11-9 11:10:51 |只看该作者 |倒序浏览
Controller marking :  PS800x (glued)
Memory chip marking :  TC58NVG4D1DTG00
Memory chip ID :  0x98D594BA
Variant 1 Author: Karol [204]
Parts of memory chips (2)
Split by dump (Dump number 2)
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
GMT+8, 2026-7-12 21:32 , Processed in 0.099934 second(s), 13 queries .
