查看: 2759|回复: 0
【SD】PS8000CC-G UT0715 [复制链接]
发表于 2011-11-9 13:08:05 |只看该作者 |倒序浏览
Controller marking :  PS8000CC-G UT0715
Memory chip marking :  TH58NVG3D4BTG00
Memory chip ID :  0x98D384A5
Variant 1 Author: kalischuk [1]
Parts of memory chips (2)
Split by dump (Dump number 2)
Block Rotate (Block Size 1024,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
Full BlockYes
GMT+8, 2026-7-12 20:36 , Processed in 0.095927 second(s), 13 queries .
