查看: 2382|回复: 0
【SD】Glued SA SM267ENU [复制链接]
发表于 2011-11-9 09:52:39 |只看该作者 |倒序浏览
Controller marking :  Glued SA SM267ENU
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  16384
Variant 1 Author: d43 [99]
1032
Change order (New order 1,0,3,2)
Marker Pos513
Mask0x0FFF
Page size 8640
Sector size 528
0-512;512-16;
528-512;1040-16;
1056-512;1568-16;
1584-512;2096-16;
2112-512;2624-16;
2640-512;3152-16;
3168-512;3680-16;
3696-512;4208-16;
4224-512;4736-16;
4752-512;5264-16;
5280-512;5792-16;
5808-512;6320-16;
6336-512;6848-16;
6864-512;7376-16;
7392-512;7904-16;
7920-512;8432-16;
GMT+8, 2026-7-13 00:51 , Processed in 0.103478 second(s), 13 queries .
