查看: 2788|回复: 0
【SD】SK6612 ACRC A0624 8S0954 [复制链接]
发表于 2011-11-9 12:28:58 |只看该作者 |倒序浏览
Controller marking :  SK6612 ACRC A0624 8S0954
Memory chip marking :  HY27UU(T)084G2M
Memory chip ID :  0xADDC8425
Capacity(Mb) :  1024
Variant 1 Author: Gefund-IT [7]
Change order (New order 1,0)
Page size 4224
Sector size 538
0-512;4176-16;512-10;
522-512;4176-16;1034-10;
1044-512;4176-16;1556-10;
1566-512;4176-16;2078-10;
2088-512;4176-16;2600-10;
2610-512;4176-16;3122-10;
3132-512;4176-16;3644-10;
3654-512;4176-16;4166-10;
GMT+8, 2026-7-12 19:01 , Processed in 0.100092 second(s), 13 queries .
