查看: 2878|回复: 0
【SD】UT0823BB [复制链接]
发表于 2011-11-9 13:08:02 |只看该作者 |倒序浏览
Controller marking :  UT0823BB
Memory chip marking :  MT29F16G08MAA
Memory chip ID :  0x2CD5943E
Variant 1 Author: pad-dataservice [17]
Full BlockYES
GMT+8, 2026-8-26 23:04 , Processed in 0.105136 second(s), 13 queries .
