查看: 2387|回复: 0
【SD】SM268BF BB QS0045.1 0806 T7D [复制链接]
发表于 2011-11-9 11:49:52 |只看该作者 |倒序浏览
Controller marking :  SM268BF BB QS0045.1 0806 T7D
Memory chip marking :  K9G8G08U0M
Memory chip ID :  0xECD31425
Variant 1 Author: Karol [204]
Translator Type 19 [SM267BB]
Variant 2 Author: Karol [204]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 19:00 , Processed in 0.099570 second(s), 13 queries .
