查看: 2251|回复: 0
【SD】Glued PCB NoName SA SM267LT [复制链接]
发表于 2011-11-9 09:52:35 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NoName SA SM267LT
Memory chip ID :  0x89D5943E
Parts of memory chips (2)
Mask0x03FF
Page size 4304
Sector size 528
0-512;512-16;
528-512;1040-16;
1056-512;1568-16;
1584-512;2096-16;
2112-512;2624-16;
2640-512;3152-16;
3168-512;3680-16;
3696-512;4208-16;
GMT+8, 2026-7-13 00:51 , Processed in 0.104659 second(s), 13 queries .
