查看: 2882|回复: 0
【SD】Glued PCB NoName [复制链接]
发表于 2011-11-9 13:47:05 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NoName
Memory chip marking :  FG64G08UCT1-21G
Memory chip ID :  0x98D79432
Variant 1 Author: michal [3]
Parts of memory chips (2)
Translator Type 2 [AU6389,AU6980,AU6981,AU6982]
Bank Size1024
Block Size8192
Add-Ins Size8
Add-Ins Offset8
GMT+8, 2026-8-26 23:40 , Processed in 0.128608 second(s), 13 queries .
