查看: 2831|回复: 0
【SD】Glued PCB HYPS4SD-060809 [复制链接]
发表于 2011-11-9 12:28:55 |只看该作者 |倒序浏览
Controller marking :  Glued PCB HYPS4SD-060809
Memory chip ID :  0xECD55525
Word Swap (Word size 1,Apply for DA+SA)
Word Swap (Word size 2,Apply for DA+SA)
Block Size512
Page size 2112
Sector size 516
0-516;
528-516;
1056-516;
1584-516;
GMT+8, 2026-7-12 18:13 , Processed in 0.098456 second(s), 13 queries .
