查看: 3095|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-11-9 13:07:59 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Memory chip marking :  HVPE4F3
Memory chip ID :  0x98D594BA
Variant 1 Author: Karol [204]
Block Rotate (Block Size 1024,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
Full BlockYES
GMT+8, 2026-7-12 18:12 , Processed in 0.097641 second(s), 13 queries .
