查看: 2508|回复: 0
【SD】noname Traxdata SD 2GB [复制链接]
发表于 2011-11-9 11:49:48 |只看该作者 |倒序浏览
Controller marking :  noname Traxdata SD 2GB
Memory chip marking :  TH58NVG4D4CTG00
Memory chip ID :  0x98D585A5
Variant 1 Author: d43 [99]
Split by dump (Dump number 4)
Block Rotate (Block Size 1024,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
GMT+8, 2026-7-12 20:45 , Processed in 0.093473 second(s), 13 queries .
