查看: 3048|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-11-9 13:47:02 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Memory chip marking :  TC58NVG3D1DTG00
Memory chip ID :  0x98D394BA
Variant 1 Author: Karol [204]
Split by dump (Dump number 2)
GMT+8, 2026-8-26 23:03 , Processed in 0.131949 second(s), 14 queries .
