查看: 2315|回复: 0
【SD】Glued PCB SM2682L [复制链接]
发表于 2011-11-9 10:31:36 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM2682L
Memory chip marking :  TC58NVG4D2ETG
Memory chip ID :  0x98D59432
Variant 1 Author: momentus [32]
Split by dump (Dump number 4)
0213
Change order (New order 0,2,1,3)
Translator Type 14 [SM267LT]
Page size 8576
Sector size 547
0-512;512-27;
539-512;1051-23;
1074-512;1586-23;
1609-512;2121-23;
2144-512;2656-23;
2679-512;3191-23;
3214-512;3726-23;
3749-512;4261-23;
4284-512;4796-23;
4819-512;5331-23;
5354-512;5866-23;
5889-512;6401-23;
6424-512;6936-23;
6959-512;7471-23;
7494-512;8006-23;
8029-512;8541-35;
GMT+8, 2026-7-12 23:15 , Processed in 0.091521 second(s), 13 queries .
