查看: 2906|回复: 0
【SD】Glued PCB SM268BB [复制链接]
发表于 2011-11-9 13:47:00 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM268BB
Memory chip marking :  K9G8G08U0A
Memory chip ID :  0xECD314A5
Variant 1 Author: d43 [99]
Copy in preparation results
Translator Type 19 [SM267BB]
GMT+8, 2026-8-26 23:03 , Processed in 0.144852 second(s), 13 queries .
