查看: 2397|回复: 0
【SD】Glued PCB NSD101-SM-PH2681-2L-2F [复制链接]
发表于 2011-11-9 10:31:35 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NSD101-SM-PH2681-2L-2F
Memory chip ID :  0x89D5943E
Variant 1 Author: Karol [204]
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x03FF
Full BlockYes
GMT+8, 2026-7-12 23:15 , Processed in 0.093798 second(s), 13 queries .
