查看: 2882|回复: 0
【SD】PS8001BE-G UT0648 P32M3.1 [复制链接]
发表于 2011-11-9 11:49:44 |只看该作者 |倒序浏览
Controller marking :  PS8001BE-G UT0648 P32M3.1
Memory chip marking :  K9G4G08U0M
Memory chip ID :  0xECDC1425
Capacity(Mb) :  512
Copy in preparation results
Block Rotate (Block Size 1024,Marker Pos 512,Id 12 34,Mask 0x0FF0 ,Small Block 16)
GMT+8, 2026-7-12 19:00 , Processed in 0.098914 second(s), 13 queries .
