查看: 2435|回复: 0
【SD】PS8005-A UT0911BB R5JJ5.13 [复制链接]
发表于 2011-11-9 09:52:29 |只看该作者 |倒序浏览
Controller marking :  PS8005-A UT0911BB R5JJ5.13
Memory chip ID :  0x89D5943E
Full BlockYES
Page size 538
Sector size 538
0-512;512-26;
GMT+8, 2026-7-13 00:51 , Processed in 0.096574 second(s), 13 queries .
