查看: 2910|回复: 0
【SD】SM266BF AB H11689 0630 S7C [复制链接]
发表于 2011-11-9 13:07:52 |只看该作者 |倒序浏览
Controller marking :  SM266BF AB H11689 0630 S7C
Memory chip ID :  0xADDC8095
Capacity(Mb) :  1024
Variant 1 Author: darkramzero [3]
Parts of memory chips (2)
Block Number Type 2 [SM32xx]
Block Size512
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-12 17:25 , Processed in 0.097101 second(s), 13 queries .
