查看: 2561|回复: 0
【SD】6612AAC 0623-022 [复制链接]
发表于 2011-11-9 11:49:42 |只看该作者 |倒序浏览
Controller marking :  6612AAC 0623-022
Memory chip ID :  0xADDC8095
Capacity(Mb) :  1024
Parts of memory chips (2)
Block Size256
Page size 2112
Sector size 546
0-512;2088-24;512-10;
522-512;2088-24;1034-10;
1044-512;2088-24;1556-10;
1566-512;2088-24;2078-10;
GMT+8, 2026-7-12 19:01 , Processed in 0.109118 second(s), 13 queries .
