查看: 2634|回复: 0
【SD】noname HAMA Sd card 1GB (Check Page size transformation) [复制链接]
发表于 2011-11-9 10:31:31 |只看该作者 |倒序浏览
Controller marking :  noname HAMA Sd card 1GB (Check Page size transformation)
Memory chip marking :  TH58NVG3D4BTG00
Memory chip ID :  0x98D384A5
Capacity(Mb) :  1024
Variant 1 Author: d43 [99]
Block Size512
Even BlockYes
Page size 0
Sector size 0
GMT+8, 2026-7-13 00:04 , Processed in 0.109486 second(s), 13 queries .
