查看: 2509|回复: 0
【SD】DIKOM SD-Card 4GB Droped [复制链接]
发表于 2011-11-9 10:41:18 |只看该作者 |倒序浏览
Controller marking :  DIKOM SD-Card 4GB Droped
Memory chip ID :  0xECD514B6
Variant 1 Author: WalRos [85]
Copy in preparation results
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
Full BlockNo
GMT+8, 2026-7-12 23:06 , Processed in 0.100322 second(s), 13 queries .
