查看: 2306|回复: 0
【SD】PS8000CC-G UT0749 [复制链接]
发表于 2011-11-9 10:02:11 |只看该作者 |倒序浏览
Controller marking :  PS8000CC-G UT0749
Memory chip marking :  TH58NVG4D4CTG00
Memory chip ID :  0x98D585A5
Variant 1 Author: AoD [9]
1302
Split by dump (Dump number 4)
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Full BlockYES
GMT+8, 2026-7-12 23:54 , Processed in 0.105221 second(s), 13 queries .
