查看: 2782|回复: 0
【SD】Glued PCB SM268BB 237-D0DJ8-LM08F [复制链接]
发表于 2011-11-9 12:38:28 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM268BB 237-D0DJ8-LM08F
Memory chip marking :  MT29F16G08FAA
Memory chip ID :  0x2CD5D12E
Variant 1 Author: Karol [204]
Translator Type 19 [SM267BB]
GMT+8, 2026-8-26 23:40 , Processed in 0.120244 second(s), 13 queries .
