查看: 2337|回复: 0
【SD】SK6612 ACRC A0641 B57658 [复制链接]
发表于 2011-11-9 10:02:07 |只看该作者 |倒序浏览
Controller marking :  SK6612 ACRC A0641 B57658
Memory chip marking :  K9G8G08U0M
Memory chip ID :  0xECD31425
Variant 1 Author: ravishankar12 [52]
Change order (New order 1,0)
Mask0x03FF
Page size 4224
Sector size 538
0-512;4176-16;512-10;
522-512;4176-16;1034-10;
1044-512;4176-16;1556-10;
1566-512;4176-16;2078-10;
2088-512;4176-16;2600-10;
2610-512;4176-16;3122-10;
3132-512;4176-16;3644-10;
3654-512;4176-16;4166-10;
GMT+8, 2026-7-13 00:04 , Processed in 0.102560 second(s), 13 queries .
