查看: 2455|回复: 0
【SD】NONAME (CnMemory Silver 1GB 60x) [复制链接]
发表于 2011-11-9 11:20:15 |只看该作者 |倒序浏览
Controller marking :  NONAME (CnMemory Silver 1GB 60x)
Memory chip marking :  TH58NVG3D4BTG00
Memory chip ID :  0x98D384A5
Capacity(Mb) :  1024
Variant 1 Author: Karol [204]
Split by dump (Dump number 2)
Block Rotate (Block Size 1024,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Full BlockYES
GMT+8, 2026-7-12 19:50 , Processed in 0.104071 second(s), 13 queries .
