查看: 2228|回复: 0
【SD】PS8005-A UT083588 P53L2.13 [复制链接]
发表于 2011-11-9 09:23:00 |只看该作者 |倒序浏览
Controller marking :  PS8005-A UT083588 P53L2.13
Memory chip ID :  0x89D5943E
Variant 1 Author: p92859198 [4]
Mask0x0FFF
GMT+8, 2026-7-13 01:44 , Processed in 0.176144 second(s), 13 queries .
