查看: 2568|回复: 0
【SD】Glued PCB SDC806 [复制链接]
发表于 2011-11-9 09:22:59 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC806
Memory chip marking :  HVPE4F4
Memory chip ID :  0x98D59432
Page XOR transformation (ID_XOR 31)
Block Rotate (Block Size 2048,Marker Pos 518,Id 1234,Mask 0x0FF0,Small Block 16)
Mask0x0FFF
Full BlockYes
Page size 8576
Sector size 562
0-512;1024-50;
512-512;1024-50;
1074-512;1024-4;2098-46;
1586-512;1024-4;2098-46;
2144-512;1024-4;3168-46;
2656-512;1024-4;3168-46;
3214-512;1024-4;4238-46;
3726-512;1024-4;4238-46;
4284-512;1024-4;5308-46;
4796-512;1024-4;5308-46;
5354-512;1024-4;6378-46;
5866-512;1024-4;6378-46;
6424-512;1024-4;7448-46;
6936-512;1024-4;7448-46;
7494-512;1024-4;8518-46;
8006-512;1024-4;8518-46;
GMT+8, 2026-7-13 01:43 , Processed in 0.099443 second(s), 13 queries .
