查看: 2360|回复: 0
【SD】SM266BF AD H14771 0731 S7D [复制链接]
发表于 2011-11-9 10:02:04 |只看该作者 |倒序浏览
Controller marking :  SM266BF AD H14771 0731 S7D
Memory chip marking :  HY27UG088G5M (HY27UF(G)084G2M)
Memory chip ID :  0xADDC8095
Variant 1 Author: momentus [32]
Copy in preparation results
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-7-13 00:04 , Processed in 0.163889 second(s), 13 queries .
