查看: 2564|回复: 0
【SD】Glued PCB C391-SD36422-02 [复制链接]
发表于 2011-11-9 11:59:18 |只看该作者 |倒序浏览
Controller marking :  Glued PCB C391-SD36422-02
Memory chip ID :  0xECD514B6
Variant 1 Author: WalRos [85]
Translator Type 14 [SM267LT]
GMT+8, 2026-7-12 17:24 , Processed in 0.097313 second(s), 13 queries .
