查看: 2639|回复: 0
【SD】Glued PCB NSD101-PHS-DG2681-2L-2F [复制链接]
发表于 2011-11-9 11:59:18 |只看该作者 |倒序浏览
Controller marking :  Glued PCB NSD101-PHS-DG2681-2L-2F
Memory chip ID :  0xECD514B6
Variant 1 Author: Karol [204]
Block Rotate (Block Size 2048,Marker Pos 512,Id 1234,Mask 0x0FF0,Small Block 16)
Full BlockYES
GMT+8, 2026-7-12 17:25 , Processed in 0.090923 second(s), 13 queries .
