查看: 2422|回复: 0
【SD】Glued PCB SM268BB_SD [复制链接]
发表于 2011-11-9 10:41:07 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SM268BB_SD
Memory chip marking :  TC58NVG4D1DTG00
Memory chip ID :  0x98D594BA
Variant 1 Author: Karol [204]
Split by dump (Dump number 2)
Translator Type 14 [SM267LT]
Page size 4304
Sector size 528
0-512;512-16;
528-512;1040-16;
1056-512;1568-16;
1584-512;2096-16;
2112-512;2624-16;
2640-512;3152-16;
3168-512;3680-16;
3696-512;4208-16;
GMT+8, 2026-7-12 23:00 , Processed in 0.216515 second(s), 13 queries .
