查看: 2792|回复: 0
【SD】SD (Glued) PHSN [复制链接]
发表于 2011-11-9 11:59:17 |只看该作者 |倒序浏览
Controller marking :  SD (Glued) PHSN
Memory chip marking :  29F64G08CAMD2
Memory chip ID :  0x89D7943E
Variant 1 Author: Artem_Galex [5]
Block Rotate (Block Size 4096,Marker Pos 518,Id 1234,Mask 0x0FF0,Small Block 16)
Page size 4304
Sector size 566
0-512;1024-50;4284-4;
512-512;1024-50;4284-4;
1074-512;1024-8;2098-46;
1586-512;1024-8;2098-46;
2144-512;1024-8;3168-46;
2656-512;1024-8;3168-46;
3214-512;1024-8;4238-46;
3726-512;1024-8;4238-46;
GMT+8, 2026-7-12 18:11 , Processed in 0.094691 second(s), 13 queries .
