查看: 2269|回复: 0
【SD】BN-3511CQ CR6369 200537 [复制链接]
发表于 2011-11-9 10:02:01 |只看该作者 |倒序浏览
Controller marking :  BN-3511CQ CR6369 200537
Memory chip marking :  HY27UF081G2M
Memory chip ID :  0xADF18015
Capacity(Mb) :  128
Split by dump (Dump number 4)
3210
Change order (New order 3,2,1,0)
Block Size256
Mask0xFF00
Page size 528
Sector size 528
0-172;176-172;352-168;520-8;172-4;348-4;
GMT+8, 2026-7-13 00:03 , Processed in 0.143467 second(s), 13 queries .
